-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   Load Range C tires (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/load-range-c-tires-20569/)
Bryan Nov 24, 2002 11:28 AM
Load Range C tires
Is anyone running load range C tires? Size 245/75/16 I am looking to soften the ride and have E tires now. Is C too much? Almost always empty.<br><br>94 2500 4WD<br><br>Thanks,<br>Bryan
Nov 24, 2002 11:56 AM
Re:Load Range C tires
Nothing below a D on a Cummins Diesel.
DJ Nov 24, 2002 01:12 PM
I don't think you could tell the difference between an E at 50psi and a C at 50psi. Use a bigger (265) tire and run less pressure. Empty you could probably get by with 35 rear and 45 front. Check your owners manual. Get at least a D rated tire you may want to carry something and the D's are rated for 3000 lbs.
Cat Cracker Nov 24, 2002 03:12 PM
I agree with Gonzo, nothing below a &quot;D&quot;. <br><br> CC.
Bryan Nov 24, 2002 03:42 PM
Thank you.
crossy Nov 24, 2002 05:00 PM
just rode in a friend of mines who has 'C's on his and it was definately softer than mine in ride with my 'E's but his handled like a marshmellow. my hangs curves better than my GMC 1/2 ton did. way better .<br>I'm looking for tires also and i am jumping up to a 265. I am trying to find out what the fitment problems are with a 99 style 17&quot; rim. I heard they hit. I found someone selling new takeoffs with the 'E' tires on them. why exactly don't they fit.? DAVE
BigBadDodge Nov 24, 2002 10:23 PM
Do not go with the &quot;C&quot; (6 ply) rating. I speak from exsperience here, I was runing Denman Ground Hawgs here in CA last summer, they were &quot;C&quot; rated and I had three tires blow out, two in the same day a mile apart on the highway. they got to warm on the highway and I guess with the wieght of the cummins they couldn't handle it. blew right out on the tread section not the sidwall either. I will never go under a &quot;D&quot; rating and after almost going off a bridge on the second blow out I am now runing &quot;E&quot; (10 ply) tires. there rated for 65 psi max I run 45psi for a fairly decent ride. <br><br>BBD
