lets talk 24 valve
lets talk 24 valve
Learning the 24 valve electronic fuel system.... OK I wanted the adrenaline quadzilla, but I'm wondering what is better. May be stupid to ask but I need to learn the difference between programmers and chips... so sorry to beat a dead horse. What do y'all think, I'm not looking for radical HP. Basically all the HP I can attain on stock turbo, I'm assuming that's around 350 to 400. I understand a programmer I can adjust a lot of parameters on my own and a chip is A lot of pre set adjustments. I just want to know what ya'll prefer and why. Thanks
Throw a quadzilla xzt+ on it put the boost elbow or a turn buckle if you have a auto,upgrade the fuel system as to not starve the vp44/inj pump,change the oil and filters and drive it...If you have a manual upgrade your clutch same if you have the slush box. More important get gauges fuel,pyro,and boost in that order,also I would not waist your money on a intake as the stock box will hold 400hp. You could also go with a 4" exhaust from the turbo back to keep egts low,and while your at it check to see if the crank case breather bottles gone. If it's not run a hose to the top of your front diff..
I like chips because there done,a programer you run the risk of Vin locking your truck if jr not careful.
bws
Apr 8, 2005 11:32 PM
DaHammer
21
Jan 22, 2004 09:11 AM
