-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   laddar bars (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/laddar-bars-199947/)
dsl kicks gas Apr 7, 2008 08:52 AM
laddar bars
im planing to build some laddar bars, i may pull a few times this summer and i pull trailers several times a week on the farm so they have to be adjustable so heres what i was thinking
2 top links, cut them in half weld in steel water line and make them long enough to reach the cab,(i would guess 4 or 5 ft) there is enough u bolt on the axle to bold the mounting plate on the back and ther is 2 holes in the frame behind the t-case if i rembmember right, the truck is in the body shop right now so i cant go out and look at it lol(**** deer)
if anybody has made a set of bars like this or has any ideas or sugestions please let me know[laugh]
high bid Apr 7, 2008 08:59 AM
there's a guy w/a 1st gen who made some just like this. I'm working on the same design but am trying to find the correct size/schedule steel pipe where the toplink will fit just inside and then weld them. Send me your email and I'll send you what I have received from this other guy.
JIT Apr 7, 2008 11:02 AM
I used 2 Hiem joints from Tractor supply and 2" pipe... they are 54" eye to eye with plenty of adjustment either way. I made some simple brackets and welded them to the bottom of the frame on the front and to the bottom of the U-bolt plate in the rear. Looks good... was simple and cost about $75.00
dsl kicks gas Apr 9, 2008 09:10 PM
ok thanks i'm in a dang welding class right now(i go to UNOH) and ive been welding for 15 years so i have nothing to do in class i figured i would do it in class [laugh] i didnt drive my truck up this week so ill have to get the stuff this weekend and do it next weekend. lol i plan on using cat 1 top links and 2 1/4 water line i dont know if i want to mount the rears to the u bolts or to the shock mounts. ive seen it both ways
my email is jwcolwell@unoh.edu
SilverSootXpres Apr 9, 2008 09:38 PM
I built mine just like JIT said he did. Real simple design and works real well.
J Lent Apr 9, 2008 10:55 PM
I have been rounding up supplies to build a set myself. I've done alot if research on the subject & I've been told that DOM [drawn over mandrel] tubing is the only tubing strong enough for the job. It has no seem & everyone recommends atleast a 1/4" wall thickness, but 1/2" is preferred.
