laddar bars
Old Apr 7, 2008 | 08:52 AM
dsl kicks gas's Avatar
laddar bars
im planing to build some laddar bars, i may pull a few times this summer and i pull trailers several times a week on the farm so they have to be adjustable so heres what i was thinking
2 top links, cut them in half weld in steel water line and make them long enough to reach the cab,(i would guess 4 or 5 ft) there is enough u bolt on the axle to bold the mounting plate on the back and ther is 2 holes in the frame behind the t-case if i rembmember right, the truck is in the body shop right now so i cant go out and look at it lol(**** deer)
if anybody has made a set of bars like this or has any ideas or sugestions please let me know
Old Apr 7, 2008 | 08:59 AM
high bid's Avatar
there's a guy w/a 1st gen who made some just like this. I'm working on the same design but am trying to find the correct size/schedule steel pipe where the toplink will fit just inside and then weld them. Send me your email and I'll send you what I have received from this other guy.
Old Apr 7, 2008 | 11:02 AM
JIT's Avatar
JIT
I used 2 Hiem joints from Tractor supply and 2" pipe... they are 54" eye to eye with plenty of adjustment either way. I made some simple brackets and welded them to the bottom of the frame on the front and to the bottom of the U-bolt plate in the rear. Looks good... was simple and cost about $75.00
Old Apr 9, 2008 | 09:10 PM
ok thanks i'm in a dang welding class right now(i go to UNOH) and ive been welding for 15 years so i have nothing to do in class i figured i would do it in class i didnt drive my truck up this week so ill have to get the stuff this weekend and do it next weekend. lol i plan on using cat 1 top links and 2 1/4 water line i dont know if i want to mount the rears to the u bolts or to the shock mounts. ive seen it both ways
my email is jwcolwell@unoh.edu
Old Apr 9, 2008 | 09:38 PM
SilverSootXpres's Avatar
I built mine just like JIT said he did. Real simple design and works real well.
Old Apr 9, 2008 | 10:55 PM
J Lent's Avatar
I have been rounding up supplies to build a set myself. I've done alot if research on the subject & I've been told that DOM [drawn over mandrel] tubing is the only tubing strong enough for the job. It has no seem & everyone recommends atleast a 1/4" wall thickness, but 1/2" is preferred.
O.T
26
May 3, 2008 09:37 AM
dieselcarpenter
Off Road / 4x4
19
Oct 16, 2007 04:53 PM
ckt_santiago
16
Apr 23, 2007 09:29 AM
Nuttymopar
Sep 16, 2004 12:48 PM
frostie
Aug 5, 2003 11:31 PM
