-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   Just Installed TST Powermax (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/just-installed-tst-powermax-19286/)
CMN_NOT_STROKN Oct 22, 2002 05:36 PM
I just installed my TST Powermax. All I can say is WOW!!! ;D 8) ;D I had no idea that it would add that much power. It feels like adding a 125 shot of nitrous to a gasser. I am impressed! Man I am really gonna need new tires by winter now ;)
admin Oct 22, 2002 05:43 PM
Re:Just Installed TST Powermax
Have you thought about taking care of your clutch anytime soon? Only reason I ask is that I didn't see that in your sig, and that's going to be an issue with power mods. <br><br>Jack
CMN_NOT_STROKN Oct 22, 2002 05:46 PM
No I haven't taken care of that yet. I plan on it soon though. Just plan on running till it breaks. I don't push it too hard very often so it should last a while.
admin Oct 22, 2002 06:09 PM
Cool deal. I don't own a manual so I can't say for sure, but I know that many people here have reported good luck going with South Bend Clutch. You may already know about them, but if not, I would give them a call. Good luck with it. Sounds like you're having fun. :)<br><br>Jack
PADZZ Oct 22, 2002 06:10 PM
Newbie question here. ::) :o what is it, how hard to install, how much $$, do they make it for the '03? Or, what's the vendor address. Thanks!<br><br>Go Chargers!!
scottrod Oct 22, 2002 06:44 PM
Cool ;D I'm either going to buy a Comp or the Tst hopefully this week... Just dunno which.... How are your egt's when on max? On edit- I see you bought a 2, I'm looking at the 3 :o
CMN_NOT_STROKN Oct 22, 2002 11:29 PM
Yes I bought a 2. Got it used for way cheap...couldn't pass it up. If you get the 3 you can only run it up to power level 6 i think if your trans or clutch if manual is stock. Level 6=Powermax 2. I will probably add an EZ later and some injectors. For now I am happy. ;D<br><br>PADZZ<br>TST Powermax is a computer to up the fueling of the stock ECM. Their website is www.tstproducts.com It was easy to install took about 30 minutes. I won't mention price here but you can find it on their site. Not sure on the '03 but if not they will soon. Give them a call.
Push Rod Oct 22, 2002 11:52 PM
[quote author=PADZZ link=board=7;threadid=6163;start=0#56119 date=1035328214]<br>Newbie question here. ::) :o what is it, how hard to install, how much $$, do they make it for the '03? Or, what's the vendor address. Thanks!<br>[/quote]<br><br>The TST Powermax is a fueling/timing box made for the second gen 24 valvers. It optimizes the fueling and timing map, and is available in three flavors: 1 (60 HP), 2 (90), and 3 (120). You can add a remote to any of these three boxes, and have a 10 level adjustable power box between 40 and 120 HP. These remotes are also available with EGT, Boost, and tranny temp gauges. For more info, head over the the TST Products site, www.tstproducts.com or a variety of the vendor sites who carry the TST line.<br><br>Install on 1998.5 - 2002s is quite easy, with three wires to run and simple mounting (remote and control box). The remotes with EGT, boost and tranny temp will be somewhat more difficult to mount, depending on the options selected.<br><br>The 03 box, while not available yet, won't be quite as easy to install, but it shouldn't be bad either. There will be plug-ins into each of the injectors, three plugs in total, and probably a power wire and ground, plus the remote.<br><br>Rod
CMN_NOT_STROKN Oct 23, 2002 12:38 AM
So from what I have just learned and what you have stated Rod, I can install a remote on mine and it is the same as the Powermax 3? It is badged as a Powermax 2 but has the &quot;phone plug&quot; in the back. Am I correct?
hellotbone Oct 23, 2002 06:33 AM
As for what I have heard yes you can cummin you just add the box to unlock the next level!
CMN_NOT_STROKN Oct 23, 2002 08:55 AM
Cool. Man I really got a good deal on the box then. I can't believe the difference the box makes. Our trucks at work are all bombed 12v but I don't think they compare. Then again I haven't put 20k behind my truck yet so I really can't compare the two, yet. Oh well, for now I am happy! ;D
CMN_NOT_STROKN Oct 25, 2002 01:20 AM
Ok, I am looking at alternate places to mount the box until I get the remote. Where do you guys have them mounted? I like being able to see it currently, but that will probably change. I have it temp. jammed into the ash tray. Convenient but not attractive. Also where is a good place to mount the remote? I am considering getting the remote with the guages. Anybody got them? How well do they work? Thanks for any input.
j28s Oct 25, 2002 05:13 PM
Yes, the TST PowerMax is a nice unit. As you can see from my sig I have the PowerMax 3. VERY easy to install, the HP/TQ that TST states is absolutely true (Dyno Proved).
CMN_NOT_STROKN Oct 26, 2002 01:44 AM
Oh I am definately aware of the power output of the TST. I was curious about the accuracy of the guages on the remote and to where most people mount the box and the remote. Any help/advice would be great. I would like it to be easily seen but out of the way, if you know what I mean.
j28s Oct 26, 2002 07:34 PM
I have the remote mounted in the flip down coin tray / ash tray or what ever you call it. Then the power unit is mounted sideways to the bottom of center console. As far as the accuracy...I would guess as close as you could get.
