Isspro Mechanical Fuel Gauge Help
Two days ago I was driving the CTD and glanced at my FP pressure and saw it at zero :o! I about had a heart attack, then calmed down a bit. Nothing seemed odd, no dead pedal, no CEL, still plenty of smoke, and I have a 95 GPH FASS, so the more I thought about it, the more I thought it is the gauge. I got home, checked for codes, none, check the connections for the gauge, looked OK.
Took the truck back out for a spin, and the gauge worked just fine. Now it looked more like the gauge. Took out the truck one more time today and again the gauge didn't work. So I'm pretty sure its the gauge. Also when I was driving, it would show like just above 0 psi, and no matter how hard I was on the throttle it wouldn't go down, so it wasn't responding to WOT at all, just completly steady. At this point I feel confident it is the gauge but can't be sure. Anyone have this problem before, and any suggestions on what it is/how to fix? I might try to call Isspro tommorow and see what they say. Any way I can check without spending $30 on a FP tester? THANKS! |
First get the obvious out of the way and change the filters.
THen I would say your gauge took a dump. Dont feel too bad I have been through 3. An autometer electric that lasted 1.5 hrs. An autometer mechanical 15 psi thats a little wore out from the FAss but has lasted for 5 years. A Stewart Warner 30 psi that lasted 5 hours to replace the above autometer. Mechanical autometer back in truck after SW was reading 0. Still going strong, needle just stays pegged at idle..... |
You running an isolater?
I threw my isolator in the garbage (what a nightmare that was). Just used a needle valve. been good for a year so far.
Originally Posted by fiveology
(Post 2199315)
Or can the mechanicals get messed up too? Mine never jumped around, always steady at 17psi. |
You want to run a needle valve - it will save the guage. Ive had my Isspro mechanical for 5 years now.
the isspro's especially - if you don't run a needle valve or some type of snubber they'll vibrate after 6 months or so and annoy you BADLY [verymad]
. . . not sure about autometer mechanical or diprocol gauges. TNutcher |
Originally Posted by TNutcher
(Post 2201019)
. . . not sure about autometer mechanical or diprocol gauges. TNutcher Growing pains for me I guess. Fortunately only a $60 mistake.[duhhh] |
I'm still on my original Isspro Fuel Pressure gauge (with needle valve) installed in 2000.
I have the same guage running on an isolator and so far no trouble. Put it in about 40 000 miles ago when I upgraded to the FASS pump.
Randy. |
