installing Rancho 9000x
How do you change out the front shocks that are mounted inside the springs? 2004 Ram 3500 quad cab
i think it is close to the same as older models, you have to remove the tower where the upper shock mount is (3 nuts) and the upper shock mount, then move the tower aside. remove the lower mount and pull it out throug the top.
