installing adrenaline
Hey, did a search through the forums but didn't read about the install of an adrenaline - what it takes and how long.
I'm considering getting an adrenaline for my stock truck (minus exhaust) and want to know what the install entails. I've got a post-turbo Pyro, I wouldn't mind installing the sensor pre-turbo for the module (or does it require post turbo?). I'm guessing in addition to my 4-inch exhaust, I'll need to install an intake to maximize the power of this box? The power numbers are not with stock injectors are they?
thanks for any help!
*****edit
So, I found the install directions but not much regarding the power numbers (I know what they are but now what is made from a stock setup).
*****edit
Its a fairly simple instal. Also you dont have to hook up any of the guages unless you want to. You could do pre or post turbo for your egt's with it. Also you might wanna look into a clutch if you get the adrenaline!
I had found and read the install instructions right after posting this and then edited my post, but I still haven't found any answers on the webs to if those numbers were created on a truck with stock intake, exhaust, injectors or turbo? Those numbers are insanely high for any of the stock components afore mentioned to be on the test rig! What were the specs for the test rig?
Darren, Quad has not yet made the "production tune" so numbers are meaningless right now. Other members have proven that this box is at least equal to the Edge Drag Comp, and other members have proven that this box will make more power than the legendary TST Smarty stack.
Redline boxes claim to make 180 HP, The TST comp claims to make 180 Hp. So the adrenaline pre release claim of 165 HP is right in there and not too lofty in my opinion. I'll bet that on the right settings, with a 99-01 5spd with a fresh Stock VP-44 and a new lift pump and filters, and at sea level, etc etc, the adrenaline could coax 195 rwhp out of an otherwise stock truck except for a blocked wastegate of course so that air was available for power.
bnold
2509
Jul 24, 2008 10:57 PM
qzilla
218
Jan 30, 2008 08:20 AM
sway825
Dec 14, 2007 07:57 PM
vzdude
Oct 17, 2007 04:32 PM
