Installed TQ lock up switch
Old Jan 13, 2010 | 07:10 PM
sheriffav8r's Avatar
You cut your wire and installed the switch inline, or what? If the switch is off, what is connecting the PCM wire to the tranny? Just a little confused....
Old Jan 13, 2010 | 11:02 PM
DodgenIt's Avatar
Sheriff, Id do it the way you said.. Tap into Orange/black and run to the switch. Then anywhere in the switch ground, put the resistor in.
Thats how I did mine and seems most have as well with no problems.
Old Jan 14, 2010 | 12:29 AM
Turbo-Dodge's Avatar
I just purchased a wire splice it snaps on over the existing wire anywhere. I stripped a small section to bare wire just to make sure it had full contact. Ran the spliced wire to the switch, then from the switch back out firewall put the resistor in and ran rest of the wire to the battery ground bolt up in front of battery. Works great. I used a stubby metal toggle switch so it wasn't long and in the way and wont break. I'll try getting a picture. I mounted my switch next to my hood release latch
Old Jan 14, 2010 | 12:45 AM
Russ Roth's Avatar
No, I cut it to make the splice instead of using something like a scotchlock connector. The wire is still hooked to the PCM and the tranny and works exactly like stock with the switch off. Wife can even drive it.
Old Jan 14, 2010 | 08:49 AM
Thanks guys, sounds like I have mine hooked up right. I do have a RadioShack lighted switch (red when off, green when on) so I had to run the setup through a relay, but it works the same.
Old Jan 15, 2010 | 06:23 PM
2500Ram's Avatar
Does it actually lockup the converter with that switch or just change the light color? (not trying to be a smarty) Only reason I ask is I had the same switch 3 way from Radio shack and it would not lockup my converter but the lights looked cool. Bought a simple on/off metal switch and it would lock up my converter. Ran the resistor on the ground leg and that cleared my codes as well.
Old Jan 16, 2010 | 08:14 AM
It works, but you have to have 12V power to the LED connector and one of the switched connectors. I ran a relay to the switch so the 12V would power the light and the relay and then switched a grounded connection from the relay. Lights work and TC lockup works. Now I just need to figure out when to use it. If I throw it under acceleration after shifting into 2nd gear it locks and then seems to stutter from 2nd to 3rd but that might just be the shift itself. I haven't tried it on 5x5 with the Juice for fear of grenading the whole thing....
Old Jan 27, 2010 | 11:42 AM
popsicle454's Avatar
ok let me ask u guys this. i have the (banks) chip, taps the wire on the vp and also taps the orange with the black tracer. same wire to lock the tc. would it hurt anything if i tap it again. would it hurt the chip or anything else?
Old Jan 28, 2010 | 08:36 PM
I don't see why it would but, don't quote me on it. My chip taps into vp but not my lock up
Old Feb 3, 2010 | 04:13 PM
tc wont lock when i manually put it in 2nd gear. is this normal???
Old Feb 3, 2010 | 04:55 PM
matthais's Avatar
wish I had a auto they can be so fast
Old Feb 3, 2010 | 07:20 PM
The grass is always greener on the other side....
On another note, the tc should not lock when you put the shift lever in "2" unless you throw the tc lockup switch. Then it should lock, I believe. My problem is that when I stomp on the pedal and then come to a stop the tc won't unlock when I have the Juice on 4 or 5. Ideas?
Old Feb 3, 2010 | 08:42 PM
k put the shift lever in 2`nd,,,throw the switch. stays unlocked. normal ???
Old Feb 3, 2010 | 09:12 PM
Are you moving when you throw the switch? Have you tried different speeds? I'm all out of guesses then.... Should lock up when moving....
Old Feb 4, 2010 | 02:29 PM
yes i am moving when i throw the switch. diff speeds too. locks in 2nd when the gear shift is in drive, but when i put it in 2nd, manually from drive, it unlocks. didnt try makin it down shift on its own though. i`ll try that next time. is what it is i guess.
