injectors
Old Mar 3, 2005 | 10:03 AM
diesel_burner's Avatar
injectors
just got my injectors in the mail today and was wondering if you guys had and tips or things that you ran into that could cause me to start throwing tools. but anyway can't wait to get these things in, and thanks for all the help in advance.
Old Mar 3, 2005 | 11:28 AM
duallydave's Avatar
Question
well i did mine last weekend,other than being disapointed in the results,it wasnt to bad,#6 fuel line is apain to get at and the conector tube is hard to get out.some guys made a special tool to get the fuel line off.i used a short 19mm wrench,i tried cutting a small section out of a box end to fit over the line like a brake line tool but it just stretched.the fuel lines were tite like a mother###.also a good idea to put a blanket or somthing over the rad and stuff to prevent your knees from damaging the air cond fins.dodge should put a gaurd in front.also only take out the 8mm bolts in the front.use the valve cover bolt to remove the injectors,pull the conectors first though.i used a small flat blade to get them out,pretty easy.the valve cover itself is kinda apain to get out,i pulled all the bolts out and wiggled towards the drivers side and it came out after removing the lift bracket.anyway let us know how she goes and the performance gains.
Old Mar 3, 2005 | 01:25 PM
do you guys have an est. on time, lokking to do them today but don't want to run out of time in the shop. thanks
Aaron
Old Mar 3, 2005 | 02:12 PM
justinp20012500's Avatar
Re: injectors
When you pull the old injectors out make sure the copper washer comes out with it.
Put some grease on the copper washer and the oring on the new sticks before you put them. That will help seat them, and keep the washer in place.
Get your self a swivel head ratchet and a 19mm crows foot. That will help with #5 and #6.
Don't forget the 30 ft/lbs torque for the high pressure lines is very critical.
Good luck.
Justin
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
