injectors
ok i dont understand how it says "200 hp injectors..." does that mean it brings the horsepower up 200 hp? so on my 03 h.o. id have 505 hp?
Re:injectors
There are no 200 HP injectors for the 03. Yet! [laugh]
Generally you can go by the numbers. 100, 125, etc. Is the power added to the flywheel in some cases and to the rear wheels in others. Depends on the vendor. |
Re:injectors
[eyecrazy] i want 200's!!!!!!!!!!!!!!!!!!!!!!!!!!!
ok if i got the 125's id have 430 at the flywheel.....now if i got 125's would i NEED a bigger turbo??? and would the edge ez work the same with different injectors?:? |
Re:injectors
Large injectors on the 03-04's need a larger turbo.
An EZ and large injectors = lots of EGT. |
