How's this for High performance aftermarket????
sorta fuzzy but they do the trick!<br><br> <br><br> <br><br> <br><br> <br><br> <br><br> <br><br> <br><br>
Re:How's this for High performance aftermarket????
Mark... just wondering if you have considered using a turbo-master instead of that boost actuated wastegate? You would have more control over that wastegate and you wouldnt have to go through the troble of trying to get that wastegate oppening exactly when you want it too.
Mark, 1st take sharper pictures then be sure to put a scale marker next to them....It's going to be hard enough to copy them if I have to guess what size everthing is! :P<br> <br>Also it's too bad that you spent all your money on your twins taht you had to sell the rest of your truck!! ;D ;D<br><br>P.S. have you climbed under your dash yet??? <br><br>L8tr KK
[quote author=StakeMan link=board=7;threadid=12832;start=0#121316 date=1048829353]<br>Mark,<br><br>Sell a turbo and get a better a camera. Was that night vision?<br><br>just kidding <br><br>Good looking setup.<br>[/quote]<br>The reason for the wastegate is to allow the use of really small primary exhaust housings.<br><br>I could actually swap in a HY30-9 off an automatic and still control boost.
[quote author=StakeMan link=board=7;threadid=12832;start=0#121316 date=1048829353]<br>Mark,<br><br>Sell a turbo and get a better a camera. Was that night vision?<br><br>just kidding <br><br>Good looking setup.<br>[/quote]<br>Yep, night vision, I didn't have the backlighting to use the color part of the camera. I'll get better pics later.. off the next set :P
[quote author=KwikKurt link=board=7;threadid=12832;start=0#121330 date=1048832827]<br>Mark, 1st take sharper pictures then be sure to put a scale marker next to them....It's going to be hard enough to copy them if I have to guess what size everthing is! :P<br> <br>Also it's too bad that you spent all your money on your twins taht you had to sell the rest of your truck!! ;D ;D<br><br>P.S. have you climbed under your dash yet??? <br><br>L8tr KK<br>[/quote]<br><br>
Mark when holding the camera up to your eye to take these pictures, it is ok to flip the welding hood up out of the way first! <br><br> Looks cool man! I bet they Rock!
