-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   Howards Cool Down Timer Review (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/howards-cool-down-timer-review-71684/)
BigBlue Jul 1, 2005 02:31 AM
I installed one on my truck tonight. I ordered it thursday night or friday night and received it today. I bought the custom one so you could mount it anywhere. I mounted mine in the kick panel above my CB (I'll get pics later). The install was very simple. Drill the holes for the switches and what not and then hook up the wires. He includes the fuse taps and what fuses to hook into. The only difference in the directions I had was the hole for the button had to be drillied to a 1/2" instead of a 3/8" hole like the directions said. I also figured out that if the washer falls out that's not supposed to, just put it back in the #3 hole. The number holes tell the switch how many clicks to make. Other than that it was a very easy install. Took me about 1hr working slow. I highly recommend this mod. Just make sure you put the start button and LED in the right position so the sticker works.:rolleyes: [laugh]
1320 Jul 1, 2005 09:07 AM
I need more information? In the last sentence it ends with "sticker" is that a typo?
How does it work? Where do you get it? How much is it?
I take it , it keeps the truck running for a period of time, after you remove the key?
How long? Adjustable?
BigBlue Jul 1, 2005 09:14 AM
No, the sticker isn't a typo. The sticker has all the positions for the rotary switch and tells you what button starts it. I put the start button on the wrong side so now I can't put the sticker on the dash telling me what's what. Oh well. Now I can tell people it's my adjustable propane controller.[laugh]
The timer hooks up to a constant hot and the engine fuse (#13 on my truck, he tells you which fuse to use). When you arrive at your destination, you set the dial to how many minutes you want it to run, push the start button, turn the keys off, and walk away. It's that easy. You can buy it from the DTR store for $95.
You can have it run for 2, 4, or 6 minutes.
Dave88LX Jul 9, 2005 06:00 PM
How do these timed ones compare to the ones that work off temperature?
caper Jul 9, 2005 08:36 PM
They work good , I like if for running into a store or somewhere , set it to 6 min and go, no worries of anyone taking off in er. Got pics in gallary where I mounted mine.
BigBlue Jul 9, 2005 09:30 PM
Exactly. And with an auto, you can't shift out of park unless the key is in the on position so no worry about anyone driving off.
BigBlue Jul 9, 2005 11:51 PM
https://www.dieseltruckresource.com/...0_0338-med.JPG
BDR2500 Jul 10, 2005 12:18 AM
Looks good man, how do you think this one would compare to the Turbo LifeSaver?
http://bakerautoaccessories.com/DTLS.main.page.html
I PASS GAS Jul 10, 2005 01:29 AM
Re: Howards Cool Down Timer Review
Is this the same guy that previously mentioned numerous times he NEVER waits to shut down, and could care less about turbo temp at shutdown? What changed?
dodgediesel4x4 Jul 10, 2005 01:44 AM
Hey pass'n gas, you hit it right on the knob, this SOB use'd to tell me the exact thing. After living w/ him for almost a year, I guess he got jealous of mine and had to get the same thing. Well atleast his turbo will live a tab bit longer now.[laugh]
BigBlue Jul 10, 2005 02:29 AM
I still don't care.[laugh] I got it because I wanted to be cool like dd4x4.[eyecrazy] [laugh]
kandgo Jul 10, 2005 07:06 AM
Re: Re: Howards Cool Down Timer Review
I remember his statement too, He is slowly coming around isn't he?? I would think that the big speaker under his rear seat is soo loud it is loosening some of that hard stuff up between his ears[laugh] [laugh] I really use my timer when pulling the RV in the summer. Goodluck,,Rick
