how much boost?
what kinda boost numbers should i be seeing with the mods it have???? about the most i can get is 25-27....
with stock injectors you're about as good as you're going to get---for more boost you need eithera different box or more injector and turbo although you may push 35psi with bigger injectors I'd think----chris
alright, im thinking about jammer 3s.....since they put more fuel in , does that mean i wont have as much fuel pressure? or will it change at all?
fuel pressure might change a little on WOT, but that should be it---chris
plug the wastegate
I'm seeing a max of 32psi w/jammer III's and va5.
CJ |
what is a "va5"??
Originally Posted by mx684
(Post 1515399)
what is a "va5"??
CJ |
I max out at ~25 psi with an ez and J Hook. Before the J Hook I maxed out at ~18.
thanks guys, thats what i was wanting to know..
| All times are GMT -5. The time now is 07:24 AM. |
