How do I limit boost?
The head was sent off to the machine shop to be checked before it went back on.
Right now I am just hating driving this thing since I still haven't put a boost controller on there. I can push hard and get it to 24 psi, but that's about it.
Also, EGT's seem a lot higher at cruising speed now... like around 900... is that normal? I coulda sworn it was a lot lower, and I was seeing lower boost numbers at cruising speed as well before these "repairs"?
The stock headgaskets are fairly tough...I'm rinning 60+psi on mine right now with the new twins
I'm on VERY borrowed time, and I'll probably be paying intrest on it soon
Chris
BTW, I have stock head bolts, stock head gasket, and 315K miles and counting! The last 100K have been at 325+hp, and saw A LOT of 40psi+ runs with the stock turbo (until it blew up
Chris
''Also, EGT's seem a lot higher at cruising speed now... like around 900... is that normal? I coulda sworn it was a lot lower, and I was seeing lower boost numbers at cruising speed as well before these "repairs"?''
Pardon me for butting in here, but something is not right with those numbers. My gut feeling is that your timing has slipped drastically.
You can adjust the wastegate to limit boost also. I have mine set to limit it to 40 psi, and I need to lower it some more.
I see about 9 psi at 65 mph (2200 rpm, egt 650).....is that bad or something
Originally Posted by Eskimo
10-20? Yikes! define "cruise"?
ex - at 70mph, I'm 650-700° with 5-7psi with my flying brick.
Originally Posted by rjohnson
CTD Nut is right!
Others have done extensive testing and your stock turbo is within the efficiency MAP at 35 psi... some say your ok up to 38 psi.
Head gasket should hold AT LEAST 40 psi. Many stock HG's are holding up to 50 psi boost! Timing set to high is the only way you will have problems.
RJ
RJ
Timing has WAY more effect on cylinder pressure and possible HG failure than does any particular boost number.
A manual boost controller goes in the boost line between the engine and the wastegate actuator. It is a valve that opens and lets boost into the stock wastegate actuator at whatever pressure you set. There are a zillion of them on Ebay, the only one I have tried is this one, and it works as advertised.
http://cgi.ebay.com/ebaymotors/Unive...QQcmdZViewItem
Ok, I bought and installed one of these. After a little adjusting I can run 26 lbs, and occasionally spike it up around 28. The truck feels a bit more like it used to, but I want to adjust it more to get boost to top out at more like 32.
EGT's seemed to have dropped to more like 850, which is heading the right direction.
When I have the 3k GSK installed I'll have the timing set then and I should be ok... I hope!
coreydr2003
Feb 11, 2008 07:21 PM
CTD_Neil
18
Apr 13, 2005 09:50 AM
Man I need to get those swapped out
