High idle box activation via remote WORKS
WOO HOO
It took 4 relays and 2 diodes, but I can now start my truck and kick in the adjustable high idle via my remote start remote.[guitar] Would have gotten my 2-lo conversion done but I picked up the wrong switch [verymad] |
Now all you need is the auto-drive feature, and your truck may be the next James Bond vehicle. Watch out Aston-Martin, here comes Dodge. [laugh]
Where are you getting the components for your 2 low kit?
A buddy of mine has a connection for the vacuum switch. Other than that, you just need a switch and about 6 inches of hose. His ID on here is bnold. The vac switch was $15 shipped. Not sure if his buddy has anymore, but he'll be able to tell you.
Just holler if you need any info. |
what high idle box are you using?
It's a home made box. It has a toggle switch that turns it on and an adjustment knob to set the idle.
Originally Posted by fade94
(Post 1493836)
The switch I have has 3, inlet, vent, and outlet.
(Post 1495438)
One port is for the vacuum line from the supply. The second port is for the line that runs to the axle. The third post is a vent. Not sure if it's needed. As long as you can supply power and stop the flow of vacuum, your switch should work.
Originally Posted by J Lent
(Post 1495503)
Are 3 ports needed? Do they all hook up to vacuum lines? My friend has a stockpile of 2 port solenoids.
What he ^ said.
