Help!!! Trying To Hook Up My Edge Box
Can't Find Data Link Plug-in On Truck End. I Have A 2002 Dodge 2500 Help
Its on the left side of the block way down low about 3/4 of the way back( pretty much under the MAP). It will have a cap on it so it may not even look like a plug, oh yea its a cummins so its probably covered in oil too....heh.
Best way to find it... Stand on the driver side of the truck, at the fender, and look down about half way down the block. It's under the fuel filter assy on third gens, I don't know if it is the same on seconds...
[duhhh][duhhh]tHANKS SOO MUTCH
Hey sorry i wasnt around to answer you pm quick enough i seen this thread so i figured you wouldnt need the pm. Glad i could atleast help ya on the fuse.
You got the box hooked up and the truck driving yet? Also did you tap the pump wire? |
