Help with Governor springs
Old Oct 21, 2009 | 06:57 PM
Kenny Rhea's Avatar
I recently installed a 3000 GSK from TST. I have their #6 plate installed. They recomend using the GSK with only a # 4 for my truck. Does anyone have any suggestions on how to tune this setup. Can I tighten the tension on my stock springs to raise fuel govern point. Can I loosen the tension on the 3000 springs to lower fuel govern point. PLEASE HELP the unknowns are driving me nuts. THANKS
Old Oct 22, 2009 | 10:13 AM
rebal's Avatar
after the spring install your RPMs should be almost the same as before the install . If the springs are to tight you will loose upper end power and RPMs to loose and the assembly could come apart , if your Idle is higher then before your probably to tight
Old Oct 25, 2009 | 08:09 AM
Kenny Rhea's Avatar
Thanks, I loosened the springs way better still have to do some tuning though
12VRoush
13
Mar 14, 2007 02:14 PM
crossy
May 22, 2005 10:33 AM
Getrealgetlifte
Mar 5, 2005 05:38 PM
mr T
17
Jan 6, 2005 11:29 PM
Monty
Feb 16, 2003 03:52 PM
