HeadGasket?
I just got the head shaved, they took 8thou off it and I was just wondering if I need to get a different head gasket to accommodate for what was taken off. Cummins said they only have one listed for my truck though. Are there others?
Originally Posted by bigd450
(Post 2189489)
there are marine gaskets that are.10 and .20 over IIRC |
Call one of the performance shops in the know.. PEAK, PDR or Schieds to get the right stuff.. I know not just any old oversize gasket will work. TATE down in Airdrie has some more information on that.
(Post 2189489)
I recommend the 12v marine gasket that has been modofied for the 12v. Better material and increased valve to piston clearance (this is always an issue with the 24v engines). No real negatives to running one either. Performance Diesel Warehouse has them in stock.
Doug |
Originally Posted by Jetpilot
(Post 2190461)
Doug |
Originally Posted by Dshiftff
(Post 2190466)
maybe another cup of coffee before posting in the AM We know whatcha mean Doug[coffee][laugh]
I have a .20 over modified marine gasket in mine. Tim babrber (TRE DIESEL)put it in with my o-rings.
(Post 2190461)
Doug |
The combustion chamber is in the piston bowl, shaving the head changes nothing.
Thanks for the information guys. I called Harry at Peak and he was telling me pretty much the same info. I got some cracks in the head, they are still holding but I am just going to throw a stock gasket back on and look for another head to get o-ringed.
Harrys a good guy, he will give you the straight goods.
All of the heads I have had had cracks, many of them you can get away with but you need to look for ones that don't go thru the seats or the injector holes. |
| All times are GMT -5. The time now is 07:54 AM. |
