have edge comp and no gages in yet can i tow on level one?
Old Mar 29, 2006 | 05:56 PM
tempoffroad's Avatar
i have a edge comp that i was going to put on tomorrow before i go out of town for the weekend I will be towing about 9k. I have a FP gauge that is running at 13wot with the vulcan kit. I was only going to tow on level one and may not even tap the pump till i get gauges. Do i have my bad idea jeans on to do this.
Old Mar 29, 2006 | 06:00 PM
BigBlue's Avatar
Don't tap the wire and you'll be fine. Running with the wire untapped will actually help because the advance timing that it throws out will actually lower EGT's about 100-200*.
Old Mar 29, 2006 | 06:30 PM
Diesel-Dan's Avatar
Level one is basicly an EZ. 2 and up start getting into the wire you tapped IIRC.......you should be fine if you keep your foot out of it.....
http://www.edgeproductsinc.com/dodge_ISB.html
Old Mar 29, 2006 | 06:31 PM
Bob Wagner's Avatar
its never a good idea to tow without gauges. If you really feel the need you should always keep the rpms up over 1900 RPM
once you start lugging the engine, the rpm's drop and the egt soar.
believe me I tow a 10k+ 5er with an auto.
Do you have an aftermarket filter set up?
Old Mar 29, 2006 | 06:49 PM
stock fuel and air set up
Old Mar 29, 2006 | 06:54 PM
Diesel-Dan's Avatar
DUDE...you went WAY backwards on that one! Better get some air flow into that motor....not to mention fuel pressure upgrade...i have seen many a VP-44 fall to a Comp!!!! How many miles on your truck? Sweet spot for the VP-44 failure seems to be around 115,000-130,000 from what i have seen.....
Edit: 170,000....wow....be carefull if its the OE!!!
Old Mar 29, 2006 | 07:12 PM
got the comp from a friend for 300 he orderd the wrong one so i got a deal. The inj pump is not oe and i have put the vulcan big line and relocatoin kit on. I have a bhaf that i can put on the truck but it is stupid loud. Sounds like it is trying to suck the fire wall in.
Old Mar 29, 2006 | 08:24 PM
Diesel-Dan's Avatar
OK...sounds like you got it under control then! hahah......
Old Mar 29, 2006 | 08:38 PM
Dan tell me what u think im new to this truck and motor just looking for help
Old Mar 29, 2006 | 10:41 PM
BigBlue's Avatar
Just to be safe put the BHAF on there and run the comp in EZ mode (no wire tap) and you'll be fine.
Old Mar 30, 2006 | 05:24 AM
Thanks for the help
Old Mar 30, 2006 | 08:11 AM
Diesel-Dan's Avatar
Yeah...i second Blue on that one....
Old Mar 30, 2006 | 08:49 AM
Olratlr's Avatar
tempoffroad! When Bombing these Trucks the First thing on your list of
things to do should be Gauges.
Old Mar 30, 2006 | 08:54 AM
HOHN's Avatar
With no wire tap, you can't hurt anything that wasn't already at risk...
Old Mar 30, 2006 | 05:02 PM
well got the comp installed today and wow what a difference on level one didnt tap the wire but did put a bhaf on it with the silincer ring still installed and wasnt that loud. cant wait to get the boost and egt installed so that i can tap the pump.
