35/S400 vs BD twins
Old 12-02-2007, 10:48 PM
GFB
GFB's Avatar
35/S400 vs BD twins
Anybody ran both? I don't want a sled puller or dyno queen. I want quick spool, decent power, and cool EGTs. I was initially thinking 35/S400 setup but have found I can get a decent price on the BD S300 twins.
Old 12-03-2007, 12:38 AM
Muddin_dude06's Avatar
I would say if the S400 has a 1.10AR housing it would be pretty much a toss-up. But the BD's are engineered together so I think it would be a better spooling set and they are probably wastegated better as well.
Old 12-03-2007, 06:17 AM
gwhammy's Avatar
Does anyone have experience with the 1.10 housing on the s400 in a twin setup. That is what I was thinking about under my 35-40. I have a 3b with the 22cm housing and it is great for towing, it's just I can get a part of a kit for a 400 pretty reasonable.
Old 12-03-2007, 09:36 AM
RonA's Avatar
The only S400 turbos I have seen that are available with the 1.1ar exhaust housing are the smaller versions with either an 83mm or 87mm turbine. These are not the "B2" version. The smaller turbine versions are almost 3 times the cost of the 96mm turbine "B2" version.
Old 12-03-2007, 10:18 AM
On E-bay you can buy an S475 or S472 with an 87mm turbine and 1.10AR for like $750.
Old 12-03-2007, 01:06 PM
RonA's Avatar
I checked ebay and did not see anything except an S475 83mm turbine. $750 would be great for an 87mm version. I'd probably buy a spare so i can quit changer compressors back and forth.
Ron
Old 12-03-2007, 02:11 PM
gwhammy's Avatar
So the standard s-400 is only available with the 1.32 exhaust housing or bigger?
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
Sixpack73
15
07-17-2009 07:31 PM
abc4yew
07-25-2006 01:06 PM
paulb
15
01-19-2006 06:23 PM
Quick Reply: 35/S400 vs BD twins
