-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   georend transmission (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/georend-transmission-231293/)
powermad Jan 28, 2009 10:24 PM
so i had my trans rebuilt and i am using my bd valve body and pressure lok. everything worked good before the rebuild. now it shifts realy bad from 2nd to 3rd it seems to slip into neutral before it shifts to third. what is causing this and how do i fix it they said it wasnt the tv cable could it be a valve body adjustment
oldblues Jan 28, 2009 11:23 PM
hi
might sound stupid but did you recheck your fluid level on LEVEL ground when warm with trany in N !
what are you using for fluid ? atf+4 only !!!
check your codes and post them, then erase them all and test drive it to see if any come back !
OPIE Jan 29, 2009 07:39 AM
Maybe too much gap in the direct drum clutches or a bad seal.
scottsjeeprolet Jan 29, 2009 10:31 AM
If it's a Goerends tranny give Dave a call.
Also i know that he wants Dextron III in his tranny's. He sends a bottle of special trans additive with all his tranny's.
Crimedog Jan 29, 2009 03:44 PM
Just to reiterate what scottsjeeprolet has said, Dave has always told me to run either ATF+3 or ATF +4 if you want to shell out extra money, but he says you get the same performance with Dextron III + a bottle of Lubeguard (can be found at NAPA or Orielly's).
powermad Jan 29, 2009 05:43 PM
i have one code p1765 and i think its a code for the lock up switch. but not sure. thats all the codes i have. the guys at my shop think it might need new springs in the valve body and we are waiting to hear back from dave still.
ctd89-99 Jan 29, 2009 06:01 PM
According to your sig you only have one of Daves torque converters. Doesn't say anything about Goerend Trans. Thanks Steve B.
powermad Jan 29, 2009 07:49 PM
all the parts in the trans are the same parts he uses the only difference is i used my bd valve body and pressure lok the clutches shafts torque converter and flex plate are all his just instead of me spending 6000 for a direct replacement i saved about 3000 doing it this way.
Big Deezul Jan 30, 2009 07:24 PM
.....and now your having issues
powermad Jan 30, 2009 08:29 PM
lol yea but its just the 2nd to 3rd shift either then that its a lot better than my old tranny.
