Fuel question???
Fuel question???
As you can see my mods below, I have an idle fuel PSI of 12 and if I stomp it it will drop to 1 or 2 psi with a steady normal driving of 7 to 8 psi. my question is am i hurting anything in the time being with a once in a blue moon stomp??? I am planning on an Airdog system REAL soon, and after I install it will i risk the VP going out with a higher fuel PSI once its installed??? I do run 2 cycle oil 1 qt to 1 1/2 qts on the last 2 tanks (since I learned about it)
To make it short, yes you are hurting your VP44 which is lubricated by the excess fuel. You will hear different stories but the majority say you don't want it dropping below 5psi ever! It is time to replace that lift pump and baby it until you've done so.
I wish i knew the link but someone posted a study on fuel lubricity additives and i believe it showed that 2 stroke oil either did nothing and in some cases takes away lubricity of diesel... Biodiesel was the best additive for lubricity. I'll try and find the study. As for the VP44 as long as there is a positive pressure your not running it dry but most people don't like it when it drops below 10 psi.
With a holley blue and vulcan system my fuel pressure never drops below 11psi floored and idles at 16-17psi.
the 1 to 2 is only when i mash it normal throttle up to speed it will stay a 5 psi then when im cruisin it is at 7 to 9 and i am going to take you alls advise and baby it till i get the airdog. Im just trying to find the best deal on it, 499 is the lowest so far
Get the Airdog and be happy.
Here is the link to the additive study.
https://www.dieseltruckresource.com/...d.php?t=185643
I would becurious to see that website talking about 2 stroke and lubrication. I would think it does take anything away but im no expert. I you motor oil, and 2 stroke oil all the time. Dont know if im hurting anything or not but it runs quieter and smoother with 2-3 gallons of oil in there with some fuel.
as far as the 2 cycle goes from what i can decifer its not such a bad idea after all i did in fact notice a quieter idle, with my hearing aids in that is haha, dont laugh Im only 33
Rick 12v CTD
Sep 12, 2011 11:49 PM
retirednak
Mar 30, 2010 11:00 PM
txasylum
Mar 22, 2008 02:47 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
