Fuel Line Banjo bolt thread pitch?
So I am working on installing a FP gauge on my truck. The truck had a big line kit on it when I got it. The lines between the lift pump, filter, and injection pump have all been replaced with larger fuel lines and no banjo bolts. I am trying to install a T so I can run the FP gauge off of it with a shut off valve.
My questin is what is the thread pitch of the stock banjo bolts that come out of the fuel filter? I have gone to home depot and a couple auto parts stores trying to match them up, but have not had any luck. Any input would be great. |
The stock bolts have metric heads, so I'm guessing they have metric threads also. I doubt the plumbing isle at home despot will have what you're after.
If my memory serves me right I think they are 12 X 1.5 mm
Bob H |
Yes, 12mm x 1.5 is correct.
