fuel gauge send unit
Old Apr 28, 2017 | 08:27 PM
calderneil's Avatar
I have a 2000 diesel that i am changing the send unit in. the old assembly had no lift pump in it, but the new one does. will this present any problems with restrictions?
Old Apr 29, 2017 | 08:25 AM
Greg Reed's Avatar
The in tank lift pumps are not known for holding good, reliable fuel pressure. They also are not extremely reliable. If one goes bad, it is a lot more work to replace it. I talked to some people with a 3rd gen a coup;e of years ago that just had their 3rd in tank pump go out. Had to be towed to a shop. $7-$800 to fix it.
If your original problem was fuel level accuracy, you can replace the float assembly. If you have to replace the whole cannister, do a search on here. Guys have removed the in tank pump and run external pumps.
Hercules
33
Aug 23, 2010 09:51 AM
mkivbren
32
Jan 14, 2008 09:34 PM
turboblue
Oct 27, 2003 07:48 PM
Lary Ellis (Top)
Feb 7, 2003 11:51 PM
