-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   Fluidamper...WOW (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/fluidamper-wow-166400/)
getblown5.9 Aug 25, 2007 07:04 PM
Fluidamper...WOW
Finally got to put mine on today with the help of a couple friends in the chapter (Thanks Scott and Travis) and WOW what a difference. The power seems to come on alot smoother, motor is quieter, and it pulls hard right thru to 3600 rpms!
Gotta say that it also really quiets down and takes vibrations out of the driveline and clutch. The trans and clutch had no rattles now and it was very fun to drive.
About half way home it started raining and I got into the pedal coming off a ramp and in 4th gear the power kinda snuck up on me and next thing you know I am sideways and the tach is reading 3800 and the truck was just smooth as can be!
Well worth it for the folks who are up and over 450hp or so!
Aosipower Aug 25, 2007 08:25 PM
Good review, just made me want one. I had a feeling balancing out the engine harmonics would make it easier for the truck to fly through the rpm's.
SPLnut Aug 25, 2007 08:29 PM
so when you p-pumping that thing?...
TxDiesel007 Aug 25, 2007 08:40 PM
made my choice that much easier
tj, whered u get the damper at? best price? I have SIlicone boots comin in, and wouldnt mind spendin teh cash on a damper
Rick
J Lent Aug 26, 2007 12:15 AM
It really does make the truck sound better & smoother. I think it is a great investment & worth every penny. I got mine from Advanced Diesel Technology 304-864-3399.
Tate Aug 26, 2007 12:19 AM
If you've got a dual disc clutch, its that much more dramatic.
J Lent Aug 26, 2007 12:47 AM
Ditto for sure.
getblown5.9 Aug 26, 2007 12:17 PM
yes it makes the DD much quieter, smoother, less nerve racking as i always hear weird rattling sounds and think something was broke.
06 DIESEL Aug 26, 2007 12:31 PM
Glad to hear that it is doing what you wanted. I was there anyway so getting dirty helping out was nothing. I might just have to put that on my list of thing to do one of these days.
Aosipower Aug 26, 2007 12:32 PM
is it hard to install?
06 DIESEL Aug 26, 2007 12:37 PM
With the correct tools it is not that bad but make sure that you have a 90* drill and a small hammer. It can be a pain at some times but over all not that bad IMHO.
getblown5.9 Aug 26, 2007 12:44 PM
remember thats only if you are doing the drill pin kit for high HP and 3600+ rpms... i did it for added security, but if you dont do the drill pin kit, this install can be done in less than an hour with a lift and prolly a little over an hour if you are laying on your back.
its basically, take the belt off the alt. pulley to make it loose, take 4 bolts out, replace damper with new fluidamper, put bolts back in, then tighten/tq them down using whatever method you can to keep the motor from turning while torquing. then put the belt back on...
pos dodge Aug 26, 2007 12:49 PM
Sweet
I ordered mine last week for $355. It should be arriving mon. or tues. I am glad to hear the good reports. ATS exhaust manifold coming as well, i hope that is worth the money.
Hammer Aug 26, 2007 01:06 PM
And you thought we all were kidding about the differences.
The difference when used with a double disc is amazing.........Andy
afoulk Aug 26, 2007 02:38 PM
posdodge, where did you find one of those for $355?
