flow adjustment for FP guage
I tried the local autoparts stores to no avail. Where could I find one (1/8 npt threads). I don't want the guage buzzing and I'm going to hook it up this weekend hopefully. Thanks
Re:flow adjustment for FP guage
I bought mine from Graingers
www.grainger.com
Needle Valve <----LINK
Rod has 'em at www.wildcatdiesel.com too.
My Hook up (Yours will be different)
https://www.dieseltruckresource.com/...6&pid=1487
www.grainger.com
thanks Ed ! Weeeeeeeeeelll, I tried to order from Grainger but they say they dont sell to 'consumers'. Maybe I can find someone who has an account with them. My setup is diffferent but the same one will work just will mount in a different location. That is exactly what I need though.
Did you hook up the guage yet? I hooked up mine (when I had the Isspro FP guage) and didnt have any troubles. I used 7' of -3 SS braided hose and ran straight to the guage from the bottom of the filter housing. There was no pulse or buzz. You know the guage already has a restrictor. If you look at the back of the guage you will see the tiny little hole that the fuel goes in, so I dont see the need for more restrictors unless your delivery line is to short.
Ohh ok, I had heard that the needle valve was needed but thanks, I'll hook it up straight this weekend and Im using the same length braided line as you had. Appreciate the info.
I ran mine without the needle valve for about a year before I started to hear a buzz in the gauge.
After installing the needle valve all was again quiet.
I was trying to recall where I'd seen my needle valve before and it finally occurred to me this is the same valve that's used to hook up refrigerator ice makers to the water line. The fitting are 1/4 NPT if I remember right. I took my extra valve into Lowes and found the right connector that I needed.
brandon.
brandon.
quicksilvr
Nov 25, 2009 09:56 AM
ralphyboy
Jan 17, 2008 08:35 PM
8mpg
May 22, 2006 01:35 PM
bigragu
Jan 24, 2006 11:16 AM
Dodgezilla
15
Mar 11, 2003 07:49 AM
