FASS Question
I have an 01 24v with an Edge EZ modual. I want to install a FASS. I am not planning any other power mods for this truck. If I install the FASS 150 can I use the stock tank plumbing, Or do I need a dip tube?
What about if I install the FASS 95? |
i have the 95gph and no pick up tube and all is well. i thhink i heard somewhere that the 150 needs the tube but don't quote me.
Stock pickup is fine.. I'm running my 150/150 with it
By "stock" do you mean you are using the factory in tank pickup?
I just installed a 150 last weekend on our '02, the instructions are straight forward and easy to follow. Pickups and return fittings on the tank stay where they are, you simply remove the stock hoses and install what FASS supplies for the install. The biggest pain in the *** for my install was the previous owner had spliced into the harness and cut the connector at the lift pump. It was just a little more work wiring, that's all.
The difference was very noticeable!!! Cheers! |
