EGT gauge
Old Mar 30, 2003 | 10:09 AM
SjLingenfelter's Avatar
EGT gauge
On the Egt gauges make sure that you dont have the power for the temp not the power for the light but the power for the temp is not connected all the time. Make sure that when you turn your key off and open the door that the gauge will turn off cause if you dont you will burn out the inside. It happen to me I dont know if it will to anyone else but just to let ya'll noobies know.<br>SD03
Old Mar 30, 2003 | 10:33 AM
Monty's Avatar
Re:EGT gauge
What exactly burnt out of the inside? I thought it was commonplace for most guys to run the pyro straight off of the battery with a fuse. ???
Old Mar 30, 2003 | 04:02 PM
Re:EGT gauge
It burns the sensors out on the inside cause there on 24/7.SD03<br>
Old Mar 30, 2003 | 10:28 PM
BigK's Avatar
Re:EGT gauge
Autometer instructions state to connect to 12v power source. They do not say &quot;switched&quot;. Perhaps an e-mail to tech info would be in order. <br>Are you referring to a different flavor of gauge?
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
Iron Horse
Mar 12, 2003 10:06 AM
dodgeboy59td
Jan 29, 2003 08:11 PM
