Edge Hot Juice low power
Not entirely sure it is I basically meant that that’s the tuner I had not really that that is the issue. Haha so my pressures are 18 psi idle 14-16 wot. Max boost is 20 psi. It just is rather sluggish and it all started after i unplugged the wire tap and plugged it back in I think. But I don’t think that has anything to do with it.
Max boost PSI of only 20 is LOW.
My old '01 with an LOCKED EDGE juice with attitude boosted to 32 PSI all the time.
Check for boost leaks.
Maybe swap the fuel filter as you are not building enough boost which may be a result of not enough fuel, or an air leak.
griffy
14
01-13-2008 05:17 PM
razor6
22
01-20-2006 03:43 PM
djcheez
10-15-2005 04:13 PM
duallydave
08-07-2005 09:38 PM
