Edge EZ died.... what to replace it with
Last winter, my Edge EZ died. I unplugged it from the IP, but left it plugged into the MAP sensor to work as a boost fooler. Anyway, I'm missing the increased performance and need to replace it with something.
I would like to replace the HY35 with an HX35, but don't know what to replace the EZ with. Any suggestions? |
Smarty, same hp as EZ with a code reader and Revo fine tuning.
BTW, I don't miss the humidity of the midwest. You from KC? Where did you go to high school, SMNW for me. |
My vote goes to the Juice with Attitude
If you were happy with the extra power from the EZ, get a Smarty!
It is by far the best of the 60 HP programers. It daily drives like a lot more power... if you use #7 or #9 power lwvwl! RJ |
If I get a Smarty, what should I use as a booster fooler? Keep using the EZ box... or is boost fooling part of the Smarty as well?
if im not mistaken, the smarty does boost fooling on its own...
Smarty has boost fooler included!
You want the S-03 Model. See HERE Smarty, with an HX-35 is a great combination! Add a set of Mach 1.6's and you'd have a sweet, very usable, 350 hp! If on a tight budget... the Bosch RV275's would also be nice (+40 hp for around $300.00)....... and would probably still work OK with your HY-35. I mention injectors only because, if your still running stock injectors, they are probable very tired. RJ |
Originally Posted by RowJ
(Post 2784509)
Originally Posted by Mechanos
(Post 2784679)
Thanks for the info. What about a set of DDP 50hp injectors? Do you think they would work ok with the HY-35? I've been wanting to swap it out for an HX-35, but $$$ has been tight with moving, 2 mortgages, etc. etc. Truck only has 154k on it.
Assume they would be less $ and the two people I know that went from DPP's to F-1 Mach injectors noticed a BIG difference. But guys that have only had DPP's seem to like them so.....? RJ |
