-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   edge comp P1693 code?? (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/edge-comp-p1693-code-146473/)
REDNECK-WELDING Apr 14, 2007 03:41 PM
i installed my edge comp today without tapping the IP and it threw the code 1693...i cant find out what one it is...any help??
BigBlue Apr 14, 2007 03:58 PM
The 1693 is just a companion code. It's no big deal.
REDNECK-WELDING Apr 14, 2007 04:03 PM
so what does it mean??? thanks
BigBlue Apr 14, 2007 04:10 PM
It means there was a code tripped. That's it. If you want you can take it to autozone and have them scan the computer and clear but I can guarantee that it'll come back. It's a code that gets tripped anytime you play with these trucks. Anyone that's ever diddled with a 24v has this code. I've had it for 6 years now with no problems.
REDNECK-WELDING Apr 14, 2007 04:14 PM
ok well i was worried as my check engine light came on...as long as theres nothing to worry about
BigBlue Apr 14, 2007 04:35 PM
You left the check engine light part out. I would get it scanned just on the chance that another code deeper in the computer got set. If the truck runs good then I wouldn't worry about it but I'd still get it scanned if the check engine light is on. Usually a 1693 doesn't turn a check engine light on.
REDNECK-WELDING Apr 14, 2007 04:57 PM
ok well i took map sensor apart and cleaned it all as it was dirty...im going to go put it back together and see if it goes away...
REDNECK-WELDING Apr 14, 2007 06:18 PM
as of now i still have the code...but the engine light is off as i cleaned all the plugs..but my alt was dirty and it started smoking alittle....damm [verymad]
BigBlue Apr 14, 2007 07:02 PM
The code won't clear itself. You can uphook the batteries and try to clear it that way or take it to an autoparts store and have it done there.
REDNECK-WELDING Apr 15, 2007 01:07 AM
ya the code is still there..but the engine light is off now that i cleaned the connections up... thanks big blue for all the help today..i will just leave the code on there
BigBlue Apr 15, 2007 03:01 AM
That's what I do. Every time I clear the codes it comes back so I ain't to worried about it. Your welcome for the help. It's why we are here. [guitar]
REDNECK-WELDING Apr 22, 2007 12:59 PM
Ok Well I Went To Install The Plate To Tap The Wire With But Had Some Problems..long Story Short After Having The Batts Unhooked The Engine Light Came Back On....***??
4RnrRick Apr 23, 2007 12:06 PM
Originally Posted by BigBlue (Post 1460300)
.... It's a code that gets tripped anytime you play with these trucks. Anyone that's ever diddled with a 24v has this code. I've had it for 6 years now with no problems.
Not true... I have no check engine codes with my edge juice with Att....
this link might help explain it...
http://autorepair.about.com/library/a/1h/bl955h.htm
Have you talked to tech support at Edge?
BigBlue Apr 23, 2007 01:07 PM
Mine has never thrown a check engine nor has anyone elses I know of but all of them at least have a p1693 code after installing a box.
NoSeeUm Apr 23, 2007 02:55 PM
My guess is that it is not the only code. How did you figure out you had a 1693 to begin with?
Jim
