edge comp P1693 code??
It means there was a code tripped. That's it. If you want you can take it to autozone and have them scan the computer and clear but I can guarantee that it'll come back. It's a code that gets tripped anytime you play with these trucks. Anyone that's ever diddled with a 24v has this code. I've had it for 6 years now with no problems.
You left the check engine light part out. I would get it scanned just on the chance that another code deeper in the computer got set. If the truck runs good then I wouldn't worry about it but I'd still get it scanned if the check engine light is on. Usually a 1693 doesn't turn a check engine light on.
this link might help explain it...
http://autorepair.about.com/library/a/1h/bl955h.htm
Have you talked to tech support at Edge?
