dtt or bd's
Anybody heard of dtt or bd Torque Converter's, vavle bodies, rebuilds? I looking for mostly a new low stall converter. were is the best and cheapest place to get one? So fare i have just heard of these two.
thanks |
Re:dtt or bd's
Do a search for DTT and ATS and you should find a lot of info on that here.
Re:dtt or bd's
A lot of info doesn't describe it. LOL. Go to www.atsdieselperformance.com and www.dieseltranstechnology.com That should give you all the information you'll ever need. I hope those are the right addresses.
Re:dtt or bd's
One of the above links didn't work but here it is:
http://www.dieseltrans.com/ and here is another one to consider http://www.suncoastconverters.com/. Do your homework. I think they all have some kind of forum. They all seem to have good products(much better than stock). They each seem to take a different approach. You will have to decide which is best for you. Give them all a call and see what they can do for you. I have called several and forget cheap. But it will be worth it. Good luck in your search. |
Re:dtt or bd's
We just installed a DTT trtanny and 240 megamentals with a hx40 and a Edge Drag Box 180hp and pull 22k every day with it and it is the best tranny hands down all the guts were replaced with billet too. It now has over 40k miles on it and works like it did the day we put it in... Go with DTT and you will not be disapointed... :)
