Dragon fire extreme VP44
Has anyone seen or used the new pump from II. It claims it puts out twice the fuel as the hotrod pump. I have an high output 6 speed and was going to put a standard pump on cause the old one is toast. From what i have read it is not an issue just bolt on and go but now this new pump sounds very interesting.
the new pump rocks! i have one on my truck and love it! no ill side effects and it pulls hard mid to top.
Yes but with the new pump if you plan on going over 100 mile road trips your going to almost have to have a fuel cooler! Just because if your not using the extra fuel the pump is putting out then its returning it bank to the tank and eventually your fuel will get warm then get cycled back threw the pump warm possibly causing pump problems!
Isin't that what all VP's do?
Yes they all do it! But they flow 140% less!!!
I have never had a problem with the fuel heating up on road trips. its only flowing 140% more when you command it to not constantly at all throttle positions. I dont think it will heat up any more than a regular vp would unless you are real low on fuel in the tank
The injection pump should have the ability to put more fuel into the engine but wouldnt the flow of my walbro 392 be the deciding factor on fuel flow to the injection pump and if not used then returned to tank?
Im not really for sure on this! Just heared it form II
| All times are GMT -5. The time now is 01:03 AM. |
