does timing advance give HP?
my truck is stock with the plate moved forward and straight piped, no other mods, does advancing the timing improve power? if so, what do you advance it to? Where can I find a step by step on the net for this? Also, when I get a TST plate, Governor spring kit and injectors, will I want to advance it more?
thanks! Lance |
Advancing the timing will...
Decrease exhaust temperature (more useable hp) Increase cylinder temperatures/pressures Increase fuel economy Increase your output of NOx (a pollutant) Decrease your output of Hydrocarbons (a pollutant) Increase the amount of black smoke at peak torque Raising the cylinder temperatures/pressures after already having increased the fueling (as a plate does) pushes the engine that much closer to its design limits, but lowering the exhaust temperature helps balance against the increased heat load from the increased fueling. 15.5 - 16° seems to do the best for a 12 valve. Instructions here http://dodgeram.info/tsb/1994/18-10-94a.htm Timing chart here http://www.piersdiesel.com/TechPTiming.htm Some folks aiming to save money advance the timing with timing tape on the dampener marked out in degrees. The problem I see with this is you must assume the timing is set correctly to begin with. About half of the trucks I've reset the stock timing on have been low, some as much as 3°. Setting timing any other way besides the plunger lift method is therefore a guessing game. For most folks it's cheaper to have a shop set the timing rather than buy the tools to do it themselves. Problem is finding a shop that will do it since it's against pollution laws to alter the timing from the factory specs. |
Infidel correct me if I am wrong, but advancing the timing ignites the fuel sooner, which leaves a longer duration for the flame front before the exhaust opens. This effectively reduces smoke. That is what had to be done on the Detroits when putting larger injectors to control smoke.
Dixie, I'm not sure how it all works but at 1000 rpm, black smoke will decrease with advanced timing, at peak rpm/ max torque load it will increase, and at the rated 1800- 2200 rpm it will decrease.
This is the reason Cummins went with variable electronic timing on 24 valves to control emissions. With 12s we're stuck with one setting though (glad we are, simple is better!) |
where do you buy those tools at and how much are they? will I ever use them again after setting it?
All of the high horsepower pulling trucks that run high rpm have their timing set crazy advanced.
Maybe somebody will care to speculate openly on how much?? --Justin |
Originally posted by PourinDiesel All of the high horsepower pulling trucks that run high rpm have their timing set crazy advanced. Maybe somebody will care to speculate openly on how much?? --Justin |
Thats sort of what I thought.
[laugh] [laugh] |
Some of the guys sled pulling are running their timing over 30°, once you get over 20° the engine gets hard to start.
Timing tools here http://buy1.snapon.com/catalog/pro_d...re&dir=catalog The Snap-On kit is about the same price you'll find anywhere. Most people will probably only need to use it once, not worth it. |
thats cool, I might get that, I get a 28 % discount from snap on being in the military.
Lance, the price Snap-On lists on their website is the very highest they charge. Along with your discount you'll get a much lower price.
You are also going to need what's called a barring tool to rotate the engine. Not sure if Snap-On has one but Cummins does, around $30. Thanks for serving! |
sweet thanks! btw do you have a part number for that barring tool?
Lance a search found these-
Cummins # 3377371; Snap On # YA9565; KD tools # 3824 |
So will I notice an increase in useable power?
Originally posted by LanceD So will I notice an increase in useable power? |
