Digital Display or Gauges?
Gauges.
The 2 people I convinced to go gauges over Monitor have no complaints. The one I couldn't wishes he would have bought gauges.
Gauges are a much more efficient way to monitor "things" without reading and distracting yourself from the road. It's really a form of anomaly detection, you only need to see when the needle is outside of it's normal range - very easy to do at a subconscious level.
my personal experience has been this, while some say mech gauges are more accurate, I dissagree. I ran both at the same time and found no variance worth mentioning.
Gauges are NOT more effective. When you have mechanical gauges you have to watch the gauges NOT the road, and why should you need to stare at gauges anyway? what if the pressure drops during the minuite your not watching a gauge? there are times you MIGHT catch an anolomy, but that would only occur if you happen to be staring at the gauge when it happens, take an EGT gauge, you would have to stare at it when at WOT towing or passing or dealing with any adverse driving conditions just to make sure you dont exceed any dangerous temps, with a monitored system it will beep, and automatically defuel your truck so that you stay in the "safe" zone all without having to watch a gauge or adjust your foot on the throttle
benifit of monitored systems is you set a perdetermined value, and drive, no need to watch the display, it will beep to alert you there is an issue. you can concetrate on what needs to be done on the road, NOT whats sitting on your dash, The only time the monitored set up is a distraction to the driver is if he is trying to mess with the monitor when driving, of which there is no reason to be adjusting parameters when driving.
only my opinion, but after having both systems, there is no way a set of gauges can ever be more effective at monitoring engine performance.
of the guys that have run both, I highly doubt the reason they switch either way is because the gauges are the best means of keeping tabs on your engine, its usually cause they like the looks of gauges better.
That's a pretty hard sell for idiot lights? Let me add that efficient != effective. You would be surprised how many people don't know the difference.
True, It may take the brain longer to process the 4 numbers rather then a needle position.. but if you have the alarms set so you dont have to look AT ALL untill one alarm goes off, then the digital wins the ease contest.
I have had both analog gauges and my J/A, I ran both for a good 8 months and they were with in 2% of each other. Now I have my Attitude along with my isspro boost gauge and I couldnt be happier.
IMO... Digital gauge monitering/ Alarms/ Multiple gauge choices/ on the fly HP increases, ALL rolled up into 1 small box, is a pretty darn good way to go in my eyes. I like my analog boost still, but I would NEVER swap my digital moniter for a full set of analogs. Especially since i'd need 10 gauges to see everything the dash cluster doesnt cover.
4 gauges minimum for the important stuff.
Again, apples to oranges. You are comparing an analog gauge to an audible alert.
My Corvette had digital display, i got used it to quick
Richie7448
19
Oct 13, 2009 01:00 PM
P.J
30
Oct 6, 2006 05:46 AM
PourinDiesel
Feb 11, 2006 06:52 AM
ckennedy
Sep 28, 2005 08:41 AM
AggiePhil
Jan 30, 2005 01:15 PM
