Difference between regular model and COMP??
Old Jan 7, 2007 | 09:37 PM
Awall's Avatar
I am wanting a TST PM3 and am wondering whats the difference between the standard product and the COMP version?? and how do you get the COMP version? Thanks- A.Wall
Old Jan 7, 2007 | 10:50 PM
Sea Bass's Avatar
If I recall, the comp is rated at 180hp vs 120hp. Also, it starts fueling sooner, and fuels to 4000rpm.
Old Jan 7, 2007 | 10:57 PM
MADMATT's Avatar
125 horse is the comp as well as the drag however its a waste of time doin the upgrade if you have a HO motor. i believe its just harder fueling in the drag box.
Old Jan 8, 2007 | 01:05 AM
Ph4tty's Avatar
The pm3 should get all the power that injector pump has to offer. What we call tst comp is actually a powermaxCE on tst's website.
I wanted the comp model because the fueling rpm range matches the smarty's. Now I have to see if I can ever get all the supporting mods together so I can actually use the higher rpms,...
Old Jan 8, 2007 | 01:11 AM
inline6power's Avatar
you guys are saying that the TST comp fuels to 4000 rpms?
Old Jan 8, 2007 | 01:15 AM
i thought only the redline box fueled that high of an rpm.
Old Jan 8, 2007 | 02:05 AM
Ph4tty's Avatar
From the FAQ on Tst's website:
The PM3 starts cutting back at 3000 RPM. The PMCE (Competition) starts cutting back at 4500 RPM.
Old Jan 8, 2007 | 09:21 AM
RowJ's Avatar
Had mine to 3600 rpm on a dyno... still pulled hard!
Rj
Old Jan 8, 2007 | 09:28 AM
blackdiesel's Avatar
Registered
Rj
mine pulls hard way up there too!
Old Jan 8, 2007 | 11:59 AM
what the heck then i baught one in the classifieds and was told it was the comp and now i no its not. mine starts to defuel at 3000. wow, after all the stacks i have tried, with the drag comp, smarty and tst, mabey there is a few more hp out there that i thought i had. looks like its time to get the real tst comp then
Old Jan 8, 2007 | 09:54 PM
Ph4tty's Avatar
It's only like $50 to upgrade it
Old Jan 9, 2007 | 01:33 AM
thats the thing, i sold it a while back becuase i thought i had the comp and my DRAG comp felt way stronger. guess i am just going to have to buy another and make sure its a comp this time.
Old Jan 9, 2007 | 08:56 AM
CTDPower11's Avatar
The COMP fuels better down low...Resulting in more smoke and better takeoff!!!
Old Jan 9, 2007 | 09:23 AM
dodgediesel's Avatar
Awall is talking about a TST brand chip, not an Edge brand!!! I would try the regular TST PM3 before you upgrade to a TST Comp. The TST Comp is a mean box to deal with and your truck probably won't enjoy it but it's a blast to play with...
Old Jan 9, 2007 | 04:02 PM
Awall's Avatar
Alright, thanks for all the help guys... I just shipped the Edge to get DRAG'd and ill use it and if i dont like it ill go with the TST
