cummins e-brake
http://cgi.ebay.com/ebaymotors/CUMMI...spagenameZWD1V
anyone have any info on this or bought one before? |
Looks interesting , I'll go see what I can find and or watch for other posts.
I just got off the phone with the local Cummins shop and they said that those E.B are for the large eng.
oh well , if the can be modifided to fit is ??? |
i got swamped at work and then lunch, thanks for makein a call. i think ill sticl with the pac brake from piers
the guys that want to run a 4 in. exh all the way from the turbo out would benefit from getting that brake, it doesnt bolt right to the turbo , it is place in the exh piping , we usually mount them on the down pipe right off the turbo. they can be mounted up to 4 feet from the turbo. you just wont get a air compressor to work that unit. so if you can or have air comp. already, it will work.
seems like a good price how much to get it to work and what els would be needed? |
John , that kit will require a air supply , if you have a compressor and a small tank , yes it will work on your 12 valve , one thing I notice not on the kit is a throttle micro switch that the solenoid can be wired so that it don't work anytime the engine is above idle. you can also get that kit from Jacob to make that kit work. I dont know what flange came with that kit on E Bay either , but they arent that expensive either to make it work , the exh piping before the brake will have to be tight with no leaks, and you can also get the gaskets for the flanges also from Jacob to make it leak free. if your truck have a vacumn pump on, it might be cheaper to just get the right kit for yours build.
| All times are GMT -5. The time now is 06:22 AM. |
