Converting a Cab and Chasis
I need some suggestions.
I have an 02 3500 dually cab and chasis with no bed. We bought a dually bed and want to put it in the cab and chasis, problem is the cab and chasis rearend is narrower than the new bed. What can I do to widen the wheel base. I have heard of spacers, they look simple, Are they safe. I haul alot of stock and cant afford fixing one problem to create another.
Thanks for you help
Thanks for you help
Originally Posted by gmctd
Gap would be good for stacks.....................
Trade diffs for the disk brake version of correct width.
Originally Posted by JDGnut
Anyone know about the width of the spring mounts on the axle?? is he going to have to move them if he uses a st dual axles?? Just curious... and shock location.. nuthing that can't be moved..
How about a regular box with bed floor notched and wheel humps chopped and sectioned to clear the inner tire, add bushwacker fender flares to cover the meats. Or just put in a lift kit and add the flares....this works!
1stgendreamer
Feb 4, 2015 08:03 AM
CoastalDav
Aug 3, 2007 10:21 AM
gman2310
Sep 27, 2006 12:08 AM
