comp or smarty
Old Jan 21, 2007 | 07:02 PM
ncdodgeman20's Avatar
Question comp or smarty
heres the deal i got an 01 dodge ram 2500 4x4 with 110,000 miles on it also stock 47re tranny that has been given a hard time but that is still holding up pretty good now things that arint stock i got a 5 inch stright pipe that is about to become a single 7 inch miter cut stack and i also have autometer fuel,tranny,pyro and boost guages installed.what i was wanting to know what would be the best bang for my buck smarty, comp or maybe even a tst but i want something to give the best power and maybe even a good little cloud of black smoke when i want i aslo tow every day about 8,000 lbs and latter in time i will be adding f1 injecters and phat shaft turbo or twins but any way what box do yall think i should go with??? thinks in advince for the advice!!
Old Jan 21, 2007 | 07:05 PM
DPS3's Avatar
i would go with the comp box first because of the larger hp gain and its on the fly adjustability and stack it with the smarty later on down the line.
Old Jan 21, 2007 | 07:24 PM
GoldGoat's Avatar
I would go with the comp, I love mine, they are very reliable boxs and put out pretty good horsepower and torque.
Old Jan 21, 2007 | 07:28 PM
how are yalls trannys holding the power and also will i leave a good cloud of smoke?
Old Jan 21, 2007 | 07:32 PM
lil Smoke's Avatar
I have both and love em! just installed the comp friday and its making my 5 speed slip. so i ordered a Southbend Con OFE.
Old Jan 21, 2007 | 07:57 PM
1stGen545's Avatar
I installed a comp on an 01 5 spd 4x4 DRW with C&M flat bed, and fabbed up an alum diamond plate intake with an AFE filter, 5" exhaust with 5" stacks outside the bed that smoke perfectly even (and by smoke i mean clouds on level 5 sub-level 5 ) and regulated the boost to 35psi. P.S. he pulled a 32' long 10' tall trailer for a moving service across the country and could run on level 3 with a stock clutch and low EGT's
dodgediesel
Jul 27, 2007 08:59 AM
CTD_Neil
Feb 23, 2006 09:27 PM
hellotbone
Jul 12, 2003 12:58 AM
hellotbone
18
May 16, 2003 04:40 PM
danlit
Feb 13, 2003 10:53 AM
