Coil spring spacer ontop of extended spring
Old Feb 23, 2008 | 10:13 PM
flynhigh205's Avatar
I was wondering if anyone on here has done this, I have 6 inch springs on my truck now and want to install a 2inch spacer ontop of that. will it be ok? any bad things about it?? thank you for your help
Old Feb 24, 2008 | 01:43 AM
Vern Calhoun's Avatar
Sounds like your talking about a "bucket". The ride shouldn't change but with the axle how it is when you get an alignment it might drive funky. Since these trucks are four linked the pinion angle must be set right or else vibration/breakage will occur. The thing that sucks is that the caster/camber with probably be off with the pinion set to the right degree, therefore causing issues with on-road drive ability. You could get a set of adjustable 4-link bars which might help you out but ultimately, and to do it right, you should(or a shop) cut and rotate the knuckles.
Old Feb 25, 2008 | 08:34 AM
kawi600's Avatar
I doubt you have stock arms at 6" of lift.. are yours adjustable? Are they made to accomodate 8" lift? If not you might have to upgrade to another long arm kit that will do 8". I know theyre out there, just cant remember where Ive seen em.
Old Feb 25, 2008 | 06:27 PM
stuckey200224's Avatar
topguncustomz can make a set
Old Feb 25, 2008 | 06:29 PM
olddodgetruck's Avatar
top gun customz sells a nice long arm kit that is not much more than a set of adjustable control arms. the long arm kit will ride much nicer because it will put the arm at less of an angle
Old Feb 25, 2008 | 09:35 PM
Dexter's Avatar
If hes only changing the front it should not make a difference when he is driving in 2Hi correct? Only when he is in 4wd would the front pinion angle matter right? Or am I completely wrong?
Old Feb 26, 2008 | 09:30 AM
juicedbusa02's Avatar
it says in his sig he has a 6" RCD lift... if that is the case then it has a shortarm/longarm setup similar to the fabtech kit .. my fabtech kit wasn't adjustable so i would doubt the RCD kit is.. BUT... you should be able to put the 2" spacer on with no problems... i have a 7" skyjacker coil with a 2" top gun spacer on top of it .. works fine !
Chris
Old Feb 26, 2008 | 10:33 AM
kawi600's Avatar
Pinion angle would be a problem as well as the axle location. Youd rub in the back a bit. Ive got some arms made for 3-5" lift and its at 3" so its forward a bit.
SimpleSailor
Apr 4, 2015 07:33 AM
benroberts3605
Jun 26, 2009 09:01 AM
WHISTLINTURBO
Mar 10, 2009 09:23 AM
Flashman
13
Sep 22, 2006 03:48 PM
DODGE4X4
Apr 25, 2004 07:13 PM
