Chip???
I own a '01 Dogge diesel p/u. I am interested in adding a chip to it to increase prformance. Where do I get one? Which is the best? And what do I need to know about it?<br><br>Thanks in Advance,<br>JLEDVM
Re:Chip???
If you are looking for a little extra zip for a reasonable price, a lot of people here start with a chip called an Edge EZ. You can buy one right here on this site. Just go to the Online Store and order away. I'm saving my pennies for one, but I'm not quite there yet. There is a review in the articles section about the EZ, you might want to read that also.<br><br>DeWain
Re:Chip???
I agree on the Edge EZ but, You may want to look at the Edge Comp for a little more money the box has different settings allowing you to contol the power a little better. As you beef the truck up you can giver a little more. And worse case you can set it low with out hooking up the pump wire and give her less then the EZ if need be.
Re:Chip???
If you dont want spend a lot you can also get a Diablo power puck it gives a little more kick than the EZ. Its what I have on my 01 and I'm very happy with it.
Re:Chip???
I agree with rocknram, skip the EZ and get the comp! There's no doubt you will start upgrading more after that, and why not just spend the extra dollars up front for the comp as opposed to trying to sell the EZ and then get a comp? ;D<br><br>Tony
Re:Chip???
Get the Comp. And this :( will change to this :) and then ;D.<br> [laugh]
