Can you upgrade to power mirrors from tow mirrors?
Old Jan 9, 2006 | 06:34 PM
B.A.Ram's Avatar
I have a guy who has tow mirrors and he is interested in switching w/my power mirrors. How hard is it to do this? Since his tow mirrors aren't power he doesn't have the defrost button or the directional toggle.
Old Jan 9, 2006 | 09:45 PM
B.A.Ram's Avatar
comon fellas, info would be appreciated.
Old Jan 10, 2006 | 06:21 AM
graphitecumnz's Avatar
it's extremely easy. I did it on my 1500 but you'll lose the power features...
Old Jan 10, 2006 | 08:29 AM
cwert87's Avatar
On my 00, I have the new model of mirrors on. The ones that you can fold in and out. Since they are for the new model trucks, the electrical stuff is backwards. So when you move it from the inside, it will be (right is left and left is right, down is up and up is down) That is the only thing that does happen when you replace it with the new model mirrors w/ 2nd gen. of trucks.
Old Jan 10, 2006 | 07:30 PM
B.A.Ram's Avatar
No I mean his truck has the tow mirrors, therefore he has none of the power equipment. I have the power mirrors therefore my truck has the power equipment. I know that when I put tow mirrors that they will not be power unless I do the 3rd gen. conversion. I want to know if he can go from non-power tow mirrors to power non-tow mirrors. That make sense?
Old Jan 10, 2006 | 08:14 PM
P.J's Avatar
P.J
He can loosen the screw at the drivers door area where his contol stickwould be. He should see an empty white wiring harness hanging there. I think there is enough give to peek in there and see. I would think they ran the same harness.
Old Jan 11, 2006 | 07:15 PM
B.A.Ram's Avatar
Thanks PJ. I assume that the control for the mirrors will just pop in? Same w/the defrost button? I wonder if anyone has done this.
Old Jan 11, 2006 | 09:23 PM
gandrews's Avatar
I had the non power tow mirrors and did the conversion to the power tow mirrors.
1-When I looked inside the door I found that the harness was already in place.
2-the control for the power mirrors was an easy replacement - although had to pay retail at dodge - note the control and the **** were two separate parts.
3-The mirror defrost button is part of the heater / AC control and not a separate item - $100+ as I recall.
The difficult part of going from non power tow mirrors to powered tow mirrors is that Dodge did not offer them in the 01 and prior years. When they did offer them in 02 they also changed the bolt pattern / mirror base - which is why it is not just a bolt on.
I assume the bases of the mirrors you are considering swapping are the same.
Note to cwert87 The plugs on the electric harness in my trucks doors did not match the electrical harness plugs in the electric mirror. I had to get other connectors (and cut and splice) to mate the truck electrical harness to the mirror electrical harness. When I was done my toggle switch works as it should ie: if I move it to the left the mirror goes to the left, or if I move the toggle switch up the mirror goes up etc.
Good luck,
George
Old Jan 12, 2006 | 02:59 AM
B.A.Ram's Avatar
gandrews, thanks for the info. That is exactly what I was looking for.
Old Jan 12, 2006 | 04:21 PM
gwhammy's Avatar
You are switching from the regular power mirrors to the non-power tow mirrors or vise-versa right. If you go ahead and do this please reply on how easy or hard it was. I would like to do this on my 01 to my wifes 02. She has the tow mirrors and doesn't like them and I have the little mirrors and tow all the time. I just hate to dive in without knowing if there is a big snap to get hooked on. Thanks
Old Jan 12, 2006 | 07:29 PM
gandrews's Avatar
I believe there is a difference in the mirror base between 01 and 02.
Go to this link for pictures on swapping electric tow mirrors (02 & up) onto the older base (01 and earlier).
http://www.turbodieselregister.com/u...&albumid=16271
Good luck
George
Jblak87
Mar 26, 2012 05:30 AM
Totallyrad
Jul 19, 2011 07:41 AM
RuralCruiser007
Jun 13, 2010 09:42 PM
zander79
Apr 27, 2007 01:38 AM
1320
Apr 30, 2004 09:13 AM
