-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   Can the 92 Cummins be turned up (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/can-92-cummins-turned-up-55641/)
tyrod Nov 29, 2004 08:17 PM
Can someone tell me how to get some extra power from a 92 Dodge/Cummins rated at 160hp and 400tq. A 50 or 75 horse jump would be great but anything would help. Dont want to hurt economy when not towing. Thanks
RCW Nov 29, 2004 08:18 PM
Visit www.dodgeram.org and follow the links to the technical articles. You can jump your power way up there and never spend a dime, other than a bit of increased pump wear.
tyrod Nov 29, 2004 08:23 PM
Thanks a million. I knew there had to be something left in there untapped. Tyrod
Clunk Nov 30, 2004 12:03 AM
After I made the pump adjustments on my '92, I had the local muffler shop replace the stock, kinked tailpipe with a 4" Walker tailpipe (stock #54150) and install 4" pipe up to the transfer case with good welds and hangers....wheelspin became a problem.
Since I was calling on my injector pump more, I used Service Power to help keep it lubed.
INJECTOR JACK Nov 30, 2004 04:28 PM
Advance your timing as well. I have seen 1st gen's brake 400 rwhp.
turbo thom Nov 30, 2004 06:29 PM
Anything with a Cummins, four wheels and a go petal can be turned up.
..Preston..
cethane Nov 30, 2004 06:38 PM
Here's another good source of info
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Smoky Dec 1, 2004 12:05 AM
There was this one time.....in fuel systems class......I turned up a VE, and it made more than twice the CC's it was supposed to....[laugh]
Mike
andyr354 Dec 1, 2004 12:43 PM
What is the origional application listed for that pipe? I was going to research that further.
Clunk Dec 1, 2004 07:28 PM
I don't know, I got the part number off a forum, but it cleared the spare tire and had lots of clearance over the rear end. The outlet was a few inches short so I gutted a 4" chrome pipe end the kids put on their doodybug cars and welded it onto the tailpipe...looked good too. Sounded good with lots of "BLAT". Also let the whole motor flow better so I could put another turn or so on the fuel screw and ended up with about 5psi more boost.
