Bypass filter decision, toilet paper....
#47
Hey guy's, this a very interesting that I ran across this thread. I was at a filter supplier on Friday and was speaking with a fine gentleman who has been dealing in the filtering business for forty plus years (Just a wee bit of experience I would say) I was asking him whether he would have replacement elements for my oilguard bypass system. He took one look at the cartridge and laughed, he said where in the heck did you get that thing from?? he said that technology is from the 50's he couldn't believe that the companies selling these systems are making claims of 10 microns filtration with string wound filters, more like 150 maybe. He went on to tell me about the toilet paper farce. He said he has personally seen dozens and dozens of engines destroyed by this type of filtration system. He said alot of people get caught up in the sales pitch and really don't understand the filtration process. Fleetguard Filters ( Strataport) are one of the best filters on the market he claimed. (also what I use) he went on to sya that with alot of the new technology filters out there it is not necessary to add addittional bypass components. Yes, I agree that if you cut a fleetguard filter apart you will find that the substrate is paper but it is a completely different composition than butt wipe. After acouple of hours speaking with this kind man I have changed my thinking with regards to my existing oilguard system. Anyone interested in buying a slightly used system cheap even has an extra cartidge. To each his own but I I'm starting to be a little more cautious about what I will do with my investment.
#48
Thank you For your kind reply remarc31. All the information I can find says that oil in a engine does not wear out. It mearly gets the additives used up by captureing the various bad elemnts of the combustion process. Full flow filters are a compromise in getting enough oil flow and removing the bad boys attached to the additive molecules. Therefore if you remove the dirt more efficiently and replace the scavanger molecules You have the best of all worlds. A clean engine is a good engine. And the really good part is you save a ton of money. It costs me arround $65.00 to change oil every 3,000 miles
1992 250 Banks, exaust brake, Rebuilt Auto Tranny at 150,000 tow 27 ft Holiday Rambler Fifth Wheel.
#50
Originally posted by Spike45
I would like to announce that we have now added a Venturi lube filter for the ISB and B5.9 engine. This will give you a Stratapore full flow element combined with a stacked disk bypass filter in one spin on shell. No extra plumbing required to install. LF9027
#51
Is that a typo or do you spend 65 bucks to change your oil??
I buy 4 jugs at Costco for 35 bucks and filters from Gino's. Not near 65 bucks an oil change and I have no special system on my truck.
#52
Guest
Posts: n/a
I'm pretty close to that and I have just a little 3L diesel in my car. I wouldn't mind pushing those drain intervals out a little bit because of this as well.
Two 5qt bottles of mobil1: $42
One Hengst oil filter kit: $9
How many qts do these wonderful cummins hold? Surely you don't mean 4 gallons do you?
#53
I live in a rv and so most places I am parked don't allow oil changes on sight. So that is the going price at most of the lube joints for three gallons of oil and a filter Besides I am older than dirt and don't do much nuckle bustin
#54
#55
Guest
Posts: n/a
I have erred greatly!
I listed on this forum that Fleetguard has released a Venturi version of the LF3894 Stratapore full flow element. I am very embarrased to say that the LF9027 was released for that "other" engine found in Ford pickups. The Venturi for the 5.9L has not been released for sale as of this writing. I cannot get an answer from anyone who is in a position to know what the hold up is? I suspect that the issue actually resides at DC.
#56
Now that it's settled that TP is good in a lot of places. does any one have a comment about where to easily return the oil to the crankcase from a by pass filter. What about right in to the vaqlve cover or into the oil fill spout. The input is easy as the turbo gets its oil from the top of the full flow filter either by Tee or I saw another opening right next to it which could be used. I hate the idea of getting underneath and punching a hole in the upper part of the pan. The oil flow I am told is about 1 to 2 quarts per minute. The return line from the turbo is an option but not easy to get at.
1992 ram 50 Banks and BD brake Rebuilt auto at 155,000 She's white and looks Cherry and I love her.
#57
Guest
Posts: n/a
Cummins Recommendations on Bypass Filter Installation
I finally found my copy of Cummins Application Engineering Bulletin, AEB 42.09, June 1994.
quoting:
"The B Series Engine lubrication flow and pressures were developed to support the engine and normal accessories such as air compressors.
Cummins Engine Company neither recommends nor encourages the use of by-pass oil filters on the B engine because improper use of the by-pass filter can result in low oil pressure, and possible reduced engine life. If a customer insists on the use of a by-pass lubrication filter, it MUST meet the the following requirements:
A. Oil flow restricted to 1 GPM by using a 2mm orifice in the by-pass filter supply.
B. A check valve in the supply line which only allows flow to the by-pass filter when the oil pressure is above 30 PSI."
I do not have this document scanned at this time but will soon. For whatever bypass system you are considering, please check with the vendor company to see that it complies with the above requirements from Cummins. This includes the use of Fleetguard LF777 spin on bypass filter. Fleetguard does not supply the check valve nor the 2mm orifice.
quoting:
#58
Guest
Posts: n/a
I would agree with that completely! I was wondering/hoping that they came with the pressure valve but I don't believe that they do. I don't have time to re-read the thread at the moment but for some reason I believe they use a 1/16" line which is less than 2mm in diameter.
#60
I'm sure the TP filters were great 20 years ago when spin on filter technology wasn't as good as today. Aside from advances in spin on filter technology oil companies have been spending millions on developing oil to handle the high levels of suit created in new egr diesel engines. CJ4 oil may look dirty but by design it captures all the crap egr engines are throwing in. If you want an extended drain interval use synthetic CJ4 5w40. I wouldn't go through the headache of adding bypass filter systems. Just my .02
