Building a carbon fiber gauge pod
Since I wanted something like a Scotty Gauge pod for my race truck, I decided to make a pod like his out of carbon fiber. Keep in mind that I've never worked with either carbon fiber or fiberglass, I think its coming along nicely. Mine is a bit longer I need switches and 4 visible gauges. Thinking that someone may enjoy following along, here's the process:
Planning.
I visited several sites, including http://www.sheldonbrown.com/rinard/carbon_fiber.htm which is ironic since I abhor bicyclists who don't share the road with me. I ended up ordering the epoxy resin, carbon cloth and misc stuff from US Composites. ( http://www.shopmaninc.com/ )
The Mold.
Making the mold seemed fairly easy. It was made from 2" PVC pipe and 1/2" foam core insulation. The gauges are spaced 2 per side. The gauge layout from left to right is pyro, boost, switches, tranny temp and a pressure gauge.
first gauge:
cutting number 2:
1-4 fit:
foam was added in between the pipes:
aluminum foil and masking taped:
Fiberglass Underlay
Since the pod has to be built up before laying the carbon fiber, a combination of fiberglass and bondo was used.
first layer of fiberglass:
the bondo before it was sanded:
tonight I layed 3 more layers of 4oz. cloth:
I'll post more when I get them finished. The test sheet of finished carbon fiber is done and I hope it's not to 'ricer' when finished. The full set of consecutive pictures is located in my signature.
brandon.
Planning.
The Mold.
first gauge:
cutting number 2:
1-4 fit:
Fiberglass Underlay
brandon.
Looks good. Fiberglass is pretty easy to work with once you figure out how to do it. I've never played with carbon fiber though. I thought you had to put it in a vaccuum and heat it up real hot to make it cure? Maybe that's just how they make the parts for lamborghinis. Let us know how it turns out.
Putting it into a vacuum will make alot stronger and better looking part because its hard to get rid of the air pockets without the vacuum. We made custom snowmobile hoods out of carbon fiber. Some were vacuum formed and others were not and you can't believe the difference in quality.
The difference in quality from vacuum formed and not vacuum forming is unbelievable.
Here is my experience with carbon fiber... I still have about 16 square feet left sitting in my freezer.
Might try and make some more carbon fiber beer holders
http://turbodieselregistry.com/forum...t=carbon+fiber
Justin
Justin
Originally Posted by Scotty
That sure looks familiar.
"I wanted something like a Scotty Gauge pod for my race truck..." "except longer" To tell the truth, I've been waiting for the Scotty Pods to appear in the DTR store for awhile now and decided I needed something else to do while I wait for my money tree to grow. And I needed an excuse for using carbon fiber. I also decided that it wouldn't be prudent to make a mold.
brandon.
Justin
Justin
brandon.
(and no, I can't make anyone one. I fear my 180lb frame would snap like a twig when a certain northern neighbor found out
