brake upgrade
I find it hard to hold my truck at the line when I launch. I once heard that guys are changing the rear wheel cylinders for a gm cylinder. Has anyone heard of this and if so what is the make and model of the truck they come from.
I also heard that with the gm cylinders you dont need an adjustable proportioning valve but it is close.
NAPA 4637337 is the part#. GM 1 ton wheel cylinders. Big improvement over OEM. No mods required, they use the same holes, bolts, and brakeline fitting.
Just change the cylinders, leave the prop valve alone.
NJTman
Jul 4, 2012 11:55 PM
LilBigd02
Feb 28, 2007 08:31 PM
RTharaldson
15
Nov 4, 2004 07:20 PM
