boost numbers
I just installed HTT Killer B2 64/14, I was just curious on what the max boost pressure is on this type of turbo? I'm only seeing around 30 psi max on stock sticks, and vp. If I upgrade those items is it possible that I could see more PSI.
Bump.
You would definitely see more boost with bigger sticks. |
30 is a good psi for that turbo- its very effecient at that level. I've run mine to 47 several times and it should be able to handle a couple more psi than that.
More Fuel = More boost!
That turbo is within it's 'Map' up to 40 psi. Lot's of room to grow. :) RJ |
thanks for the info, I'm waiting to get my tranny done before anymore mods occur. Then it balls to the wall, stage 5 jammers, HRVP, Fass LP
Originally Posted by RowJ
(Post 1529028)
