Boost Elbow Install and Check Engine Light On
Old Jul 27, 2019 | 01:22 PM
SkyHarborCowboy's Avatar
I installed a boost elbow and it upped the boost from 17psi up to 22.5psi with exhaust temps around 1000 pre-turbo. The weird thing is the check engine light came on.
Ill scan it but any ideas what can cause that with only that change?
Old Jul 27, 2019 | 01:32 PM
P1740 figures more power equals transmission issues.
Old Jul 27, 2019 | 04:20 PM
AlpineRAM's Avatar
P 1740 does not correlate to boost. (Torque converter solenoid code)
but-
Just using a boost elbow or any other device to increase boost over stock levels will lead to de-fueling in the first step ( programmer thought wastegate sticking, reduce fuel, customer goes to mechanic, better than grenading stuff) and if de-fueling does not work with a check engine light and a limp mode.
So you need either a boost fooler ( so the ECM does not register the higher boost) or some ECM software that accepts this higher boost. (like Catcher/Smarty software that accepts much higher boost than stock)
Old Jul 27, 2019 | 09:11 PM
but-
Any recommendations for a boost fooler?
Old Jul 28, 2019 | 12:59 AM
SIXSLUG's Avatar
Edge ez is relatively inexpensive and does the trick, 3 levels. Mine stays at 2...
Old Jul 28, 2019 | 01:42 AM
AlpineRAM's Avatar
Boost fooler not cooler..
Either some Edge box, Quadzilla etc or a Smarty.
Read up on these boxes in the forum, there are a lot of different things to consider before getting one.
Old Jul 28, 2019 | 02:05 AM
Boost Cooler was an Auto-Correct, lol.
Old Jul 29, 2019 | 09:39 AM
Danderson's Avatar
Those EZ's are hard to beat. My friend's going on 20 yrs with his on a 2nd gen 24v. That and RV275's have been in the whole time. Zero issues and a clean exhaust.
Hdog
Oct 27, 2014 10:52 AM
97dodgeram2500
Nov 1, 2009 11:51 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
ratboy3124
Sep 26, 2006 11:38 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
